Date/Time: Tue, 04 Feb 2025 06:52:52 +0000
[User Discussion] - London and Asia Session (highs and lows) Indicator
View Count: 1930
[2020-01-12 18:12:53]
User94606 - Posts: 327
Is there an indicator that would plot the the London session (high and low) and the Asian session (high and low)?
[2020-01-13 18:53:27]
John - SC Support - Posts: 37688
The study you want is documented here:
High/Low for Time Period
Note that there are really 2 studies documented - High/Low for Time Period and High/Low for Time Period - Extended. The Extended version allows you to extend the lines to the end of the chart. So which one you use will depend on how you want to view the data.
[2020-01-14 00:12:58]
Thank you. For the start and end time on the High/Low for Time Period | High/Low for Time Period - Extended study, do I need to convert to my default sierra chart time zone? In other words, London trading hours are from 8 AM to 4:30 PM (3 AM - 11:30 AM EST). Do I use 3 AM - 11:30 AM EST on the study?
Do you have the trading hours for all the world's major exchanges: London, Tokyo, Shanghai, Hong Kong, Australia, etc..
[2020-01-14 15:12:06]
The time that you set in the study is whatever the time zone is of the chart that you are applying the study to. So if the study is on a chart that is set Eastern Standard Time then you would need to set the times in the study to 3:00am and 11:30am for the London Session. But if your chart is in London Time, then you would set 8:00am and 4:30pm.
We do not have the trading hours for the exchanges, you would need to just look them up online.
[2020-01-14 16:40:40]
I noticed when I use either study my bar charts get compressed. Is there a way to not to compress the charts?
[2020-01-14 17:21:44]
Set the Study Scale to be Same as Region. Refer to the following documentation for this:
Chart Scale and Scale Adjusting: Same As Region (Scale Range)
