Date/Time: Sun, 19 May 2024 09:22:17 +0000
Chart Drawing Time
View Count: 931
[2020-01-12 18:04:03] |
fobglobal - Posts: 51 |
Hi, How can improve the chart drawing time of a chart? I have noticed that some charts have a better drawing time than others. Thanks |
[2020-01-12 22:15:24] |
Basically reducing the complexity of what is on it and using solid Line styles.
