Date/Time: Thu, 28 Mar 2024 21:24:27 +0000
Notice: Internet Connectivity Issue Affecting Certain Services
View Count: 801
[2020-01-12 16:49:45] |
There is an Internet connectivity issue from Verizon which is affecting our historical futures data which is provided for some services like the Denali Exchange Data Feed, the Sierra Chart Historical Data Service and the delayed CME Group Data feed. This problem also affects connectivity for the delayed CME group data feed. Verizon says it will be resolved by 3 PM 2020-01-12. If not, we will take the appropriate steps to route users to our other servers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-12 16:50:09
[2020-01-12 23:55:18] |
The problem is still not resolved. This problem is currently affecting the delayed data feed. Implementing a workaround for this will take some time. It is been running on more than a day. The delayed data feed has no automatic redundancy. This really is astonishing that Verizon cannot even get this problem resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-13 00:29:26
[2020-01-13 00:33:18] |
This is just a test post.
[2020-01-16 09:01:19] |
We want to update this post to indicate that the problem was resolved by Verizon Sunday evening 2020-01-12
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-16 09:01:34
