Date/Time: Sun, 19 May 2024 16:09:18 +0000
Does ESH20-INX require an exchange activation?
View Count: 467
[2020-01-10 20:31:27] |
SierraFan - Posts: 84 |
Sierra, ESH20-INX is appx 20mins behind/delayed. Do I need to activate something to get live data? If so can you direct me where? Am I doing something wrong or is normal for the ESINX data? Thank You
[2020-01-10 21:29:09] |
Yes. This requires the S&P Indices exchange also activated in addition to the CME exchange. You just have CBOE Indices.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-10 21:29:21
