Date/Time: Sun, 19 May 2024 11:05:13 +0000
HE Spreads Not able to open
View Count: 501
[2020-01-10 17:56:59] |
EquinoxAnalytics - Posts: 10 |
Hi I was able to open Spread charts, I updated Applicationg and trying to open Spread charts but nothing happens. (Get Spread) button not pulling spread contracts
[2020-01-13 18:01:38] |
We are looking into this.
[2020-01-13 19:24:00] |
This problem is now resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
