Date/Time: Sun, 19 May 2024 14:15:15 +0000
Problems with routing,
View Count: 582
[2020-01-10 16:19:13] |
User912405 - Posts: 14 |
Hello SC, The routing of the Denali data Edutest001 / AMP 122828 does not seem to run. I would like to run everything about AMP directly now. After many days back and forth, I don't have the time to investigate what happened. I would like to get everything directly from AMP now. What exactly should I do so that I can get back to work after 3 days of System Stop? Hi, on this edutest001 account, you have live data via the Denali Feed, would you like to do a remote assistance session so we can make sure you are experiencing it? For using 2 separate installations of Sierra Chart, getting the Denali Feed on both + linking each to a different broker: Using Multiple Data and Trading Services at the Same Time also read the documentation here about using this feature Data/Trade Service Settings: Saving and Loading Service Settings |
[2020-01-10 17:22:30] |
SC Support - Posts: 1801 |
We have messaged you on skype about this. Lets connect there.
[2020-01-10 20:25:54] |
connected with the client on Skype, all questions answered
