Date/Time: Sun, 19 May 2024 11:41:13 +0000
Support for Alternate Historical Forex Data
View Count: 619
[2020-01-10 16:16:25] |
ycomp - Posts: 277 |
what does the checkbox: Support for Alternate Historical Forex Data do?
[2020-01-11 16:42:18] |
There is a replacement for this, and it is documented here: Interactive Brokers Trading Service: Using Sierra Chart Historical and Real-time Forex Data and Trade through Interactive Brokers Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-11 17:06:48] |
so it only relates to one specific broker? IB?
[2020-01-11 18:47:37] |
This method works with any service. Including Interactive Brokers.
[2020-01-12 08:12:59] |
so it's possible to use Sierra Chart forex data to chart and execute trades through LMAX?
[2020-01-12 20:05:09] |
User138602 - Posts: 169 |
Why would you want to do that?
[2020-01-12 23:35:21] |
In regards to post #5, yes technically but it is more complicated in the case of LMAX. To do this in the case of LMAX you need to use this method: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart So you would need to have another installation of Sierra Chart installed using SC Data-All Services and access the EURUSD data from that instance in the instance connected to LMAX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-12 23:36:54
[2020-01-13 05:46:30] |
"Why would you want to do that?" I like the way SC Forex data looks in SC (FXCM I guess) compared to LMAX but I prefer LMAX to FXCM for execution... FXCM variable spreads as far as I understand it require a min. 20k balance. |
