Date/Time: Sun, 19 May 2024 11:41:15 +0000
Trading DOM sim P/L values not correct when using
View Count: 551
[2020-01-10 10:56:10] |
User316362 - Posts: 210 |
I have a trading DOM setup with the Symbol set to "ES" and the Trade and Current Quote Symbol set to "MES" for example. When SIM trading, the "trade Window" on the left summarizes P/L and DPL in terms of ES, not MES as it should. Also in the trade activity LOG, the correct MES sim trades are shown. It seems like Live is the same way. Correct Trades being placed and in the activity log but trade window totals for P/L are for the wrong contract. Side Note: other charts show the correct values at the same time in an attached trade window Version 2033 Date Time Of Last Edit: 2020-01-10 12:01:20
[2020-01-13 21:43:32] |
Adjust the Currency Value per Tick setting: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
