Date/Time: Sun, 19 May 2024 16:36:19 +0000
Simplify loading chart for large list
View Count: 547
[2020-01-09 20:48:36] |
LucentTrader - Posts: 35 |
I have a quote board with the S&P 500 equities. Is there a method to update all of these symbols without selecting each one independently and waiting for the download to complete. Preference is to initiate the download and return later and have each chart available without having to download.
[2020-01-10 01:02:12] |
Yes, refer to: Global Settings Menu: Intraday File Update List (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-10 13:45:20] |
I am in need of historical download. The above referenced process is for intra day unless I am missing something. Is there a similar process for Historical data? |
[2020-01-11 15:56:22] |
Yes. Refer to: Changing the Symbol of a Chart: Using the Associated Watch List And: Changing the Symbol of a Chart: Downloading Historical Daily Data for Symbols List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
