Date/Time: Tue, 04 Feb 2025 06:55:48 +0000
Sierra Chart is up to date no updates were downloaded when upgrading from v2028
View Count: 519
[2020-01-09 16:50:46] |
T44 - Posts: 363 |
https://www.sierrachart.com/index.php?page=doc/Whats_New.php shows current version is 2031
Untitled.png / V - Attached On 2020-01-09 16:49:49 UTC - Size: 20.27 KB - 245 views |
[2020-01-09 19:09:01] |
The current version is 2028 so what you see does make sense.
