Date/Time: Tue, 04 Feb 2025 06:59:54 +0000
previous days vpocs
View Count: 694
[2020-01-09 09:17:41] |
Rustam - Posts: 19 |
is it possible to have the pocs of the last 5 trading days displayed continuously ?
[2020-01-09 23:24:27] |
John - SC Support - Posts: 37688 |
One thing you can do is to put on 5 Volume Value Area Lines studies and set the Reference n Periods Back to 1, 2, 3, 4, and 5 in each of the studies respectively. You will also want to turn off the Value Area Lines subgraphs and change the colors for the POCs. Refer to the following for this study: Volume Value Area Lines And refer to the following for working with the Subgraphs: Chart Studies: Subgraphs Tab For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-10 00:20:03] |
I tried it with VbP und set start date and end date. But it shows me a lot more days and didn`t end at the end date. http://www.sierrachart.com/image.php?Image=1578615517503.png |
[2020-01-10 00:33:37] |
If using the Volume by Price study, you would want to use a Volume Graph Period Type of One Period at End of Fixed Time Length and set it to 1 Day and then adjust the reference days back accordingly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-10 00:34:27
