Date/Time: Mon, 25 Nov 2024 01:28:07 +0000
Using FXCM symbol data in another chartbook
View Count: 1155
[2014-01-02 05:09:48] |
Willson - Posts: 176 |
I have OEC Data feed for futures data. If I subscribe to FXCM trading level, can I use the FX symbols (EUR/USD) as a chart input in my Futures chartbook? (I also plan to trade using FXCM so I am choosing live FXCM rather than SC provided FX data). If I can combine futures charts (OEC data) with FX charts (FXCM Data) in one chart book, will I need a separate instance (install) of SC that contains only the FXCM data?? Help appreciated |
[2014-01-03 16:38:09] |
Yes, you can do that. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html You will need a separate instance of Sierra Chart installed on your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
