Date/Time: Wed, 05 Feb 2025 06:40:57 +0000
Display old (but still valid) order level while adjusting an order level via chart trading
View Count: 633
[2020-01-08 15:26:54] |
User648557 - Posts: 13 |
Hello, is it possible to display the old / former (but still valid) level of a stop or limit order while adjusting the level via moving the horizontal order line up or down? During the process of moving the order line but before confirming it by unclasping the mouse button, I am only able to see the new / intended order level. During faster markets I sometimes forget about the exact valid order level which means that I am kind of surprised by the execution when I am still in the process of adjusting my order level. I am a former NinjaTrader 8 user, where this function is supported via chart trader. I would also be fine with workaround where e.g. a new dom trading column would display the valid order level. Thanks in advance. |
[2020-01-10 13:39:20] |
just to be sure that you get me correct, here a screenshot of how NinjaTrader solves the issue...
NT8_OrderAdjustment_ChartTrader.png / V - Attached On 2020-01-10 13:38:51 UTC - Size: 257.77 KB - 257 views |
[2020-01-22 16:39:57] |
Any thoughts here? Thanks. |
[2020-03-03 13:41:24] |
Hello SierraDesk, could you pls estimate if it would be possible at all to program a solution like that: - Implement a new column to the Chart Dom, which shows the former (but still valid) level of a pending stop and limit order while modifying the level the order? thanks you in advance. |
