Date/Time: Sun, 19 May 2024 12:53:12 +0000
QO symbol missing
View Count: 519
[2020-01-08 09:08:49] |
User392279 - Posts: 67 |
I'm currently using Deli Data. I only see it under SPREAD not under NYMEX.
[2020-01-10 19:37:50] |
John - SC Support - Posts: 31705 |
We have added the symbol QO-######-NYMEX-USD-50 to the symbol settings for Interactive Brokers. Update your Symbol Settings and then you should be able to find the listing for QO. Refer to the following for updating Symbol Settings: Global Symbol Settings: Update Symbol Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
