Date/Time: Mon, 25 Nov 2024 00:28:34 +0000
SC Forex FXCM Data update issue
View Count: 1204
[2014-01-02 01:08:04] |
test99 - Posts: 26 |
Starting January 1 2014 there is no live data pushed through SC Forex FXCM data feed. I am using 1066 release of SC. I have seen your message about new server update and wondering if there is any changes I have to do in setup of data feed. Up to Jan 1 there was no issues with FXCM forex data whatsoever. Please resolve. Thanks Is it because FXCM is closed in Jan 1 2014 and will reopen on Jan 2 at 2am ET? Date Time Of Last Edit: 2014-01-02 01:25:33
[2014-01-02 01:28:38] |
FXCM is closed now.
[2014-01-02 01:29:05] |
THanks
