Date/Time: Sun, 19 May 2024 15:52:12 +0000
Inaccurate hourly candles
View Count: 945
[2020-01-08 02:18:32] |
user10000 - Posts: 41 |
I just noticed that 60mins+ candles are all different than what tradingview is display. I confirmed with 2 other platforms and they both have the same candles as tradingview. Not sure what i have to do in order to fix this. Attached is the 4hour/240min charts from sierra and tradingview http://www.sierrachart.com/image.php?Image=1578449864973.png https://www.tradingview.com/x/TKZbIT8Z/ Date Time Of Last Edit: 2020-01-08 02:19:20
[2020-01-08 14:20:47] |
The reason would be due to the starting time of the chart bars which can be changed. Refer to the documentation here for this: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
