Date/Time: Sun, 19 May 2024 15:10:05 +0000
Dashed Box around TPO Study now when selected
View Count: 624
[2020-01-07 19:12:32] |
Profile Trader - Posts: 168 |
I have made some type of setting change and now when I click on my TPO profile I get a dashed box outlining it. DO you know what I would have changed so I can change it back... Thanks, Doug |
[2020-01-07 23:29:50] |
Your Sierra Chart account is expired. Login with Help >> Support Board to make sure you are using the correct one. The reason you see this is explained here: Time Price Opportunity (TPO) Profile Charts: Keyboard Shortcuts for Splitting and Merging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-07 23:32:15
