Date/Time: Mon, 16 Sep 2024 20:10:36 +0000
Sierra Chart set up instructions.
View Count: 1222
[2014-01-01 19:29:11] |
robna - Posts: 18 |
Can a Sierra chart be set up without the stock market being active and connected to TWS?
[2014-01-01 19:33:42] |
Yes it can be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-02 16:00:03] |
robna - Posts: 18 |
I need to change my chart to 1 min. It stays on Dly. How do I change this?
Date Time Of Last Edit: 2014-01-02 16:50:47
[2014-01-03 02:55:24] |
vegasfoster - Posts: 444 |
Method 1, Press F5 and change the drop down menu at the top center from "Historical" to "Intraday", if necessary, and then change the Bar Period drop down menu to "Days, Minutes, Seconds" and then use figures of 0,1,0. Method 2, click on the chart you want to change and type 1m, for 1 minute. You can also type #v for volume charts, #t for tick charts, #r for range charts. |
[2014-01-03 03:08:30] |
Refer to the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
