Date/Time: Sun, 19 May 2024 15:10:06 +0000
[Programming Help] - Problems with the ratio study (Market stats symbols).
View Count: 618
[2020-01-07 01:25:05] |
Elias3330 - Posts: 4 |
I need to work on the NVOLSP/TVOLSP internals ratio. As at the beginning of the day the TVOL value is very small the ratio is extremely out of range, which distorts the graph of the day and other studies as a linear regression channel. I tried to change the session time and skip the first few minutes but the charts settings return to the regular opening time on these internals symbols. I really need your help or some idea to solve this. I leave an image attached.
Date Time Of Last Edit: 2020-01-07 01:29:53
Screenshot at Jan 06 21-16-15.png / V - Attached On 2020-01-07 01:29:45 UTC - Size: 110.94 KB - 228 views |
[2020-01-07 23:43:44] |
Refer to this section here: Chart Session Times: Session Times Automatically Changing Unexpectedly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
