Date/Time: Wed, 24 Apr 2024 20:27:23 +0000
Easy Solution to CME Funded Trading Account Requirement
View Count: 10043
[2020-08-02 21:04:36] |
User281657 - Posts: 6 |
Ok so I would have to notify AMP that I want to switch off CQG to Denali exchange & add SC data feed in order to be able to continue my futures trading but have live stock data ?
[2020-08-03 21:06:36] |
If you just the real-time stock data you just need to follow the instructions on this page here and use this service: Sierra Chart Exchange Data Feed No other changes needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-26 00:45:45] |
User788984 - Posts: 28 |
i have subscription to Denali Data feed, but for some reason, my charts have stopped showing bars since 8/18. T&S chart shows up-to-date data. Any idea what I should be doing differently??
[2020-08-26 03:57:12] |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-28 01:59:40] |
I reviewed the whole Section 3 and still can't see bars on charts past August 18th. ??????
[2020-08-28 05:25:49] |
What is the symbol of the chart? Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-28 05:26:18
[2020-08-28 23:43:03] |
It seems I asked the same type of question about a month ago. Your recommendation then was to try to DISCONNECT and to re CONNECT again. I just tried this and it worked. Thank you!
[2020-08-29 03:29:35] |
User751739 - Posts: 29 |
I've signed up through AMP and am paying for SC package 5, I've also signed up directly on the SC website for package through some confusion. After signing up with AMP I was informed that I cannot get a live feed for US equities only futures. Is there a way for me to get live equities feed?
[2020-08-30 19:11:53] |
In response to User751739: AMP does not have access to enable and bill for the Sierra Chart Exchange Data Feed, which is what you need to use to get the U.S. Equities data. You can still get it, but that particular data feed and exchange fees will have to be paid directly through us (Sierra Chart) and cannot be billed through AMP. Refer to the following information regarding using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-30 19:12:26
[2020-08-31 15:06:35] |
user459212 - Posts: 12 |
Hello I followed the instructions in the first post 3 weeks ago in order to get live data. Now I want to trade live on the AMP account that I opened. On the AMP trading initialization screen it asks me what TT services I want to sign up for. I thought I was already paying for these services through Sierrachart. Is there some mechanism by which I will not be charged twice? I was under the impression that 25 dollars a month for Denali Exchange feed, plus Sierrachart time, plus per-side contract fees, was the most that I would be paying per month, or is this not accurate? Thanks |
[2020-08-31 15:14:24] |
Yes this is correct. You just need to let AMP know you are paying for everything yourself. Continue with step 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-03 12:56:59] |
Sundowned - Posts: 7 |
Hi there, I have account with Amp that I currently subscribe to CQG data and routing, I understand that denali is fully able to integrate and allow me to continue routing through cqg. I pay for my Sierrachart directly on this website, and I was hoping to subscribe to the denali feed in the same way. The website seems to prompt me that I must pay exchange fees, in addition to the feed, which is fine, but I already ahev a funded account and subscriptions so is there a place I can fill in those details? otherwise instead of the 31.20 for cqg, it becomes 31.20+25+31.20 I understand from the documentation that I need to confirm my funded account once a month, which i understand. I should mention one other thing, I did speak with amp about subscribing to denali directly there, which mayhave solved this problem, but they said that because I paid for sierra directly they could not help me with getting the denali feed? Any details are appreciated thanks! |
[2020-09-03 19:05:04] |
Sundowned - You can get the Denali Exchange Data Feed and continue to trade through CQG. As AMP stated, your account is directly with us, therefore you would pay for the Denali Exchange Data Feed directly to us, you cannot pay for it through AMP with your account the way it currently is. When you are going through the setup for the Denali Exchange Data Feed, you will enter your brokerage information in the Subscriber Agreement form that you need to fill out. This is how we know that you have a trading account to begin with. Once you have the Denali Exchange Data Feed setup, you can cancel the data from CQG. You will find the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* You still do have to pay for the exchange fees directly through us for the Denali data feed but you can cancel them through your CQG account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-30 04:05:50] |
TraderTen - Posts: 80 |
I would like to use your data with an introducing broker with Dorman in Chicago by the name of Tradovate. I do not see them on your list of brokers that qualify for Exchange data discounts. Will it still work?
[2020-10-30 09:50:52] |
Yes but only if they set you up with a CQG trading account: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-30 09:51:07
