Date/Time: Sun, 19 May 2024 13:52:04 +0000
DOM recenter upon ticks travelled
View Count: 642
[2020-01-06 21:44:08] |
User269836 - Posts: 6 |
Hello! Is there a possibility for the dom to recenter upon X ticks moved? It would be really useful to have the dom recenter like every 5 ticks or 5 minutes. I am really sorry if it’s already a function, but I haven’t found anything like that. Thank you! Bence |
[2020-01-07 19:14:29] |
Not exactly like this, but refer to the different Constant Range Scale Modes here: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-07 19:38:03] |
Thank you, that will do! :)
