Date/Time: Sun, 19 May 2024 15:52:19 +0000
Help
View Count: 582
[2020-01-06 20:48:44] |
Broker88 - Posts: 2 |
From 9:31 to 9:35 I had no trades on the bid on NQH20, would like to know if that was a problem of my data, attached an image. Also as a result the VbP Ask Volume - Bid Volume resulted in a lot buying. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=34250 The other question is if there is a way to highlight the biggest bars on VbP Ask Volume - Bid Volume, for example as you can highlight POC on VbP. Thank you very much. |
[2020-01-06 23:55:56] |
It sounds like you are actually not receiving the Denali Exchange Data Feed data. Make sure you are connected to your live Gain Capital account: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Follow these instructions to redownload the data, which will correct the past data: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) It is not supported to highlight the longest bars in the VbP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-06 23:56:24
