Date/Time: Sun, 19 May 2024 14:15:12 +0000
[User Discussion] - Two positions/trades in opposite direction at the same time?
View Count: 605
[2020-01-06 20:36:08] |
User430957 - Posts: 6 |
Is it possible to have two positions/trades in opposite direction at the same time? And every trade/position to have its own SL and TP? If yes, how? For example: LONG @50, SL=40, TP=70 SHORT @60, SL=70, TP=40 |
[2020-01-07 19:32:22] |
This is not supported unless you are using two separate trading accounts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-07 19:35:32
