Date/Time: Sun, 19 May 2024 14:54:32 +0000
From windows 7 to windows 10
View Count: 949
[2020-01-06 20:17:54] |
User188188 - Posts: 7 |
I am going to upgrade from windows 7 to windows 10. 1) Will my Sierra settings, background, studies, etc stay exactly the same? 2) In a case that something goes wrong and I need to re-install windows and install Sierra again, what files I should copy before that after re-installing Sierra all my settings, background, chartbooks, studies, etc will be exactly the same? |
[2020-01-07 00:10:24] |
1. If you are able to do an In-Place Upgrade, where the Sierra Chart installation folder is not cleared, everything will remain the same with it. 2. In any case, refer to the information here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-07 00:10:57
