Date/Time: Sun, 19 May 2024 14:15:14 +0000
How to get values for custom studies for prior dates?
View Count: 501
[2020-01-06 19:42:43] |
William Sherman - Posts: 1 |
How can I get values for the custom studies I have applied to my charts for prior dates? Thanks in advance!
[2020-01-06 22:03:41] |
Zosimus - Posts: 345 |
You have to check this with the provider of the custom study. Some custom studies are built to process and show results for historical data and some are built to start working only with live data after the chart finished loading. If your study is not built to process historical data you may still be able to see its results on previous data by running a replay but you should verify this the supplier. |
