Date/Time: Sun, 19 May 2024 14:15:09 +0000
ETA for CME iLink order entry interface?
View Count: 486
[2020-01-06 14:28:24] |
User138602 - Posts: 169 |
Greetings, can you make an ETA for: SC orderrouting through the CME direct link + web based trading interface. This would be my personal call to change my current SC setup. Thx |
[2020-01-06 14:49:51] |
The basic interface is not that involved. We are just working on this in our available time. So this is why it takes a while. Probably would be finished within 30 days but then the next more time-consuming step is the redundancy implementation which will take months. And then there is a whole certification/approval process involving clearing firms and the CME. This is just something that is still quite a ways away.
