Date/Time: Tue, 15 Apr 2025 14:27:26 +0000
[Programming Help] - Read & parse CSV
View Count: 2269
[2020-01-06 13:14:36]
User462086 - Posts: 196
Hi, in order to read a CSV file from disk then parse out certain fields from each line I've been trying to get 'sc.ReadFile' to work but can't seem to figure it out (code below with comments compiles fine). Stack Overflow has tons of examples for C++ but most utilize 3rd party libraries. In the past I've used 'fgets' in AmiBroker's C-based scripting language.
1) What's the best way to accomplish this in Sierra Chart?
2) If 'sc.ReadFile' is the best way, how do I get the file's text from the 'Buffer' (pointer)
Many thanks!!
Edit: using version 2028
#include "sierrachart.h"
SCDLLName("Test_ReadFile")
// support function
DWORD GetFileSize(const SCString& PathAndFileName){
  HANDLE File = CreateFile
          ( PathAndFileName
          , GENERIC_READ
          , FILE_SHARE_READ | FILE_SHARE_WRITE
          , NULL
          , OPEN_EXISTING
          , 0
          , NULL
  if (File == INVALID_HANDLE_VALUE)
    return INVALID_FILE_SIZE;
  DWORD FileSize = ::GetFileSize(File, NULL);
  CloseHandle(File);
  return FileSize;
// main
SCSFExport scsf_Test_ReadFile(SCStudyInterfaceRef sc){
  SCString DebugMessage;
    // int/bool %d; float %f, %g, %e; string %s
    // DebugMessage.Format("caption : %d",var);
    // sc.AddMessageToLog(DebugMessage, 0);
  SCInputRef FullPath  = sc.Input[0];
  if (sc.SetDefaults){
    sc.GraphName = "Test_ReadFile";
    sc.AutoLoop = 0;
    FullPath.Name = "Full Path to Text File";
    FullPath.SetPathAndFileName("");
    return;
  int FileHandle;
  bool FileOpened = sc.OpenFile
            ( FullPath.GetPathAndFileName()
            , n_ACSIL::FILE_MODE_OPEN_EXISTING_FOR_SEQUENTIAL_READING
            , FileHandle
  if (FileOpened==false)
    return;
  DWORD BytesToRead = GetFileSize(FullPath.GetPathAndFileName());
  if (BytesToRead==INVALID_FILE_SIZE)
    return;
DebugMessage.Format( "BytesToRead : %d", BytesToRead );
sc.AddMessageToLog( DebugMessage, 0 );
  char* Buffer;
  unsigned int* p_BytesRead;
  bool FileRead = sc.ReadFile
            ( FileHandle
            , Buffer
            , BytesToRead
            , p_BytesRead
  if (FileRead==false)
    return;        // <- this executes = something is wrong with my 'sc.ReadFile' call
DebugMessage.Format( "Buffer : %s", Buffer ); // <- when the line above is removed this returns "(null)"
  sc.CloseFile(FileHandle);
Date Time Of Last Edit: 2020-01-06 13:20:20
[2020-01-06 14:16:14]
FWIW, this seems to be working as expected. Any comments/improvements welcome.
    sc.AutoLoop = 0;
    return;
  std::ifstream input(FullPath.GetPathAndFileName());
  for( std::string line; getline(input,line); ){
    DebugMessage.Format( "line : %s", line.c_str() );
[2020-01-06 17:37:28]
User907968 - Posts: 840
In the first post:
char* Buffer;
No memory is allocated to Buffer, you have simply declared Buffer as pointer to char.
You can use this function to check problem with sc.OpenFile:
ACSIL Interface Members - Functions: sc.GetLastFileErrorCode()
Also, you could also use functions from SCString class for handling data that is read in:
ACSIL Programming Concepts: Working with SCString, Text Strings and Setting ACSIL Structure Member Name Strings
e.g.
SCString::ParseLines()
SCString::Tokenize()
Maybe some of this is helpful, or maybe you looked at these already.
[2020-01-06 23:37:48]
We have updated the documentation in regards to this. You have to allocate the Buffer and provide its size. Refer to the updated ACSIL documentation for this function.
[2023-06-26 09:30:12]
Zorin - Posts: 19
With all the utmost respect, both functions you've recommend to use - SCString::ParseLines() and SCString::Tokenize()- are very poorly documented and have no any basic examples - for example, for working with files, basic read.
The single example which I could find was from the study RequestValuesFromServerAndDraw.cpp - practically, no any comments there and it's heavily relying on using pointers (most people who are not familiar with C / C++ concepts would be rather using arrays - simpler to read & understand).
Please update the relevant documentation providing a couple of appropriate (easy enough for "copy-paste") examples so people don't have to re-invent the wheel every time when trying to read & parse something from the file.
[2023-06-26 10:08:55]
Sierra_Chart Engineering - Posts: 19226
Why is it you are using these functions? You can use the C++ standard library string class and functions. You do not have to rely upon anything Sierra Chart is providing.
[2023-06-26 10:28:08]
Zorin - Posts: 19
... you are using these functions? You can use the C++ standard library ..
Because it's your site, your functions, and they're described in SCSstring section, and code would look better and easier to read .
PS just trying to help my son - he was trying to do everything by the book & couldn't work it out.
[2023-06-27 08:07:08]
I couldn't work it out either, so started using the various forms of 'fstream' instead.
Referencing the code in the first post, replacing
char* Buffer;
with
char Buffer[BytesToRead];
results in 'Buffer' being filled with the contents of a file.
[2025-04-04 04:22:08]
drinkcodejava - Posts: 24
Here is a snippet of sample code that works for SCString::ParseLines() and SCString::Tokenize().
std::vector<SCString> Lines;
std::vector<float> FloatVals;
std::vector<char*> Tokens;
dataString.ParseLines(Lines); // dataString is an SCString that is data read from a file
for (SCString line : Lines) {
  msg.Format("Line as string: %s", line.GetChars());
  sc.AddMessageToLog(msg,0);
  // msg.Format("Float values: ");
  // line.ParseLineItemsAsFloats(FloatVals);
  // for (float value : FloatVals) {
    // msg.AppendFormat("%.2f, ", value);
  // msg.AppendFormat("FloatVals size: %d", FloatVals.size());
  // FloatVals.clear();
  msg.Format("Tokens: ");
  line.Tokenize("\t", Tokens);
  for (char* p_Char : Tokens) {
    msg.AppendFormat("%s, ", SCString(p_Char).GetChars());
  msg.AppendFormat("Tokens size: %d", Tokens.size());
There are a few lines commented out for ParseLineItemsAsFloats(). For this function to work, dataString must be comma-separated values (with or without whitespace after each comma). Text gets parsed into a 0 value. There is something strange with the resulting FloatVals vector though; the .size() return value seems to be 1 less than the actual. Weird.
Here is sample data:
Date  Time  Open  High  Low  Close  Vol
2025-04-03  00:33:00  -161  225  -221  63  0
-161.01  225.5  -221.99  63.241  0.05
And here is the output (for the above code, as-is):
Line as string: Date  Time  Open  High  Low  Close  Vol
Tokens: Date, Time, Open, High, Low, Close, Vol, Tokens size: 7
Line as string: 2025-04-03  00:33:00  -161  225  -221  63  0
Tokens: 2025-04-03, 00:33:00, -161, 225, -221, 63, 0, Tokens size: 7
Line as string: -161.01  225.5  -221.99  63.241  0.05
Tokens: -161.01, 225.5, -221.99, 63.241, 0.05, Tokens size: 5
If you need help figuring out how to get sc.ReadFile() working, there are some working examples here: How to read file with sc.ReadFile()?
