Date/Time: Sun, 19 May 2024 13:39:02 +0000
Paid service but getting current service package does not support this function
View Count: 491
[2020-01-06 05:06:00] |
user122307 - Posts: 1 |
I recently created an account and had a free trial but I was not getting any data feed so I went ahead and paid for the 12 month standard package. I am getting data feed now but I can not use an analysis which require order flow data. I keep getting an error. I did an update to current version (SC 2028). I also closed the software and did a force login. Both did not work.
[2020-01-06 05:35:29] |
You need the Advanced service package . We have set your Sierra Chart account to that package. This will go into effect in a couple of minutes: Set active status for Service Package to '5 - Advanced' till 2020-10-09.
