Date/Time: Sun, 19 May 2024 16:09:28 +0000
Global settings sim vs live
View Count: 490
[2020-01-06 01:53:57] |
Disabling Trade >> Trade Simulation Mode On only does just that. It has no effect on Global Settings. This is not making any sense to us. Tell us one setting you are referring to that is not getting applied. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-06 02:03:21] |
grayfrog - Posts: 35 |
Figured out. Very sorry.
