Date/Time: Sun, 19 May 2024 12:53:01 +0000
Chart Replay not working
View Count: 1612
[2020-01-06 01:30:23] |
Mak - Posts: 11 |
I have tried this on 2 computers and get the same results. I can not seem to get the charts to replay correctly, especially when using multiple charts. I have included a screen shot of the 1,5,15,60 min charts and one screen shot from all of them together. The prices don't match with varying prices and it does not back fill the charts even on a single chart replay. Any idea where I can start diagnosing the problem? I have tried redownloading the data and that didn't do anything. https://i.imgur.com/JmcgET0.png https://i.imgur.com/HbStXFh.png https://i.imgur.com/PV6zYSW.png https://i.imgur.com/Bul4Zcs.png https://i.imgur.com/XxKh7WA.png Thank you for any help |
[2020-01-06 01:56:20] |
It sounds like you are trying to start a replay back in time earlier than the chart is loading data. First thing to do is to not use " Use Start Date-Time". More information: Replaying Charts: Replaying Chart from Specific Date-Time And if you want to replay multiple charts, be sure the use the appropriate Charts to Replay option on the replay window to control that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-06 01:56:56
[2020-01-06 14:05:23] |
Mak - Posts: 11 |
That fixed, thank you. "You need to enter a Date-Time, which is not earlier than the first Date-Time in the chart." I didn't realize I had to load the charts with at least the same amount of backfill as the start date before starting the replay. |
