Date/Time: Sun, 19 May 2024 15:10:09 +0000
[Programming Help] - Plot RTH Mid Point
View Count: 962
[2020-01-05 20:31:49] |
Alex_C - Posts: 1 |
I'd like to plot the mid point for the RTH session as a continues line. can anyone help
[2020-01-06 00:11:20] |
cmet - Posts: 538 |
One way to do it is to use High/Low for Time Period and then use Study Subgraph Average to plot the mid.
[2020-01-06 01:47:51] |
This can be accomplished with the Daily OHLC study: Daily OHLC: Displaying Midpoint of High and Low Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
