Date/Time: Sun, 19 May 2024 14:15:15 +0000
New pc data
View Count: 577
[2020-01-05 17:42:01] |
User575399 - Posts: 305 |
I got a new PC (I normally use my laptop). Loaded SC onto it , logged in under my normal user ID and password . My chartbook is there but things are missing and my settings aren’t the same as my laptop settings. Should I download the data file from my laptop onto a thumb drive and upload it into my new PC Sierra chart data folder ? Thanks
Date Time Of Last Edit: 2020-01-05 18:18:26
[2020-01-05 23:04:28] |
You can copy the Sierra Charts folder to the new PC. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
