Date/Time: Tue, 07 Jul 2026 15:27:26 +0000
[User Discussion] - Debugging code of Custom Bar Charts functions
View Count: 1199
[2020-01-05 16:36:15]
Zosimus - Posts: 345
Usually, when I write a regular custom study function (SCSFExport sc_StudyName(SCStudyInterfaceRef sc)) I use the help of sc.AddMessageToLog for debugging but with the function that builds the custom studies (SCSFExport CustomBarBuildingFunctionName(SCCustomChartBarInterfaceRef ChartBarInterface) it is not possible to use the sc.AddMessageToLog. I probably can send data to a text file instead but this may slow the function down quite considerably. I should be grateful for any idea for a replacement sc.AddMessageToLog for code within the Custom Bar Chart building function.
[2020-01-05 17:13:31]
ganz - Posts: 1048
yon
How did you come to this conclusion?
http://www.cplusplus.com/reference/cstdio/fopen/ will do the job and be sure it will be definitely faster then any f() atop on it.
[2020-01-05 17:16:32]
Thank you ganz, it was just an unsubstantiated assumption. Gonna try it.
[2020-01-06 06:21:13]
ganz - Posts: 1048
yon
https://stackoverflow.com/questions/11573974/write-to-txt-file
[2020-01-06 08:55:34]
Thank you very much ganz.
