Date/Time: Sun, 19 May 2024 16:09:32 +0000
Fib Bands
View Count: 2219
[2020-01-05 00:47:21] |
wingz - Posts: 121 |
At some point, there was a study on the study list called Fib Bands. It's no longer there. Is it still available under another name maybe? If not,I would really like to see that study added back to the list.
[2020-01-05 01:43:12] |
Ackin - Posts: 1865 |
first try this: Menu/Analysis/Studies - Add Custom study -> User Contributed Studies .... Fib Bands If you don't have a library on the list you can find it here: Add custom study | Post: 200272 In the attachment you have a file that you copy to the Data folder in your Sierrachart directory and after restart Sierrachart you can try "add custom studies" again or another way try install the User Contributed Studies Run the installer again through Help >> Download Current Version and enable Install Optional Components. Also make sure Sierra Chart is not running in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Important: enable Install Optional Components option on the installer program |
[2020-01-05 17:14:41] |
aaah........it's in User Contributed Studies..........Thank You very much
