Date/Time: Sun, 19 May 2024 14:46:33 +0000
Trade and Current Quote Symbol not replaced when blank
View Count: 514
[2020-01-04 19:40:19] |
joshtrader - Posts: 442 |
Imagine that for symbol "X" there is a Trade/Quote Symbol defined as "X2" in Symbol Settings. Imagine that for symbol "Y" there is NO Trade/Quote Symbol defined in Symbol Settings. On a given chart, when symbol "X" is loaded, the "Trade and Current Quote" symbol box will now have "X2". If the symbol for the chart is changed to "Y", I would expect the "Trade and Current Quote" box to be empty, since there is no Trade/Quote Symbol defined for "Y". However, the box will still contain "X2". This changed somewhere between build 1970 or so and 2021, which is what I'm on. It seems to be an error, don't you think? I could get around this by setting the Trade/Quote symbol to be the same as the main symbol when there's no alternate Trade/Quote symbol, but this seems an unnecessary workaround. Date Time Of Last Edit: 2020-01-04 19:41:02
[2020-01-05 16:43:38] |
We will implement a solution for this.
