Date/Time: Sun, 19 May 2024 02:33:45 +0000
Cannot use my own file path for Write Bar Data to File
View Count: 621
[2020-01-04 19:17:54] |
Halco - Posts: 92 |
Study "Write Bar Data to File". If I leave the "File Path" blank it will write to the default SC\Data directory but when I enter my own "File Path" the data will not write to it. For instance - y:\Trade\SC Data or y:\Trade\SC Data\ - it will not write.
Date Time Of Last Edit: 2020-01-04 19:19:13
[2020-01-05 04:06:51] |
Make sure that folder actually exists. Since the folder is not going to get created automatically. We are also going to update the study function to use our common function for writing bar and study data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-05 04:07:22
[2020-01-05 16:02:10] |
Halco - Posts: 92 |
The folder definitely exists. Still won't write to it. I'll wait and see if the update fixes it. Thanks.
[2020-02-07 22:44:19] |
Halco - Posts: 92 |
Any idea when this will be fixed? I even tried writing it to my C: drive root, doesn't work. Only writes if I leave it blank, to the default SC Data folder.
[2020-02-10 11:23:59] |
The updates described at post #2 were done at that time. We cannot reproduce the original issue.
