Date/Time: Wed, 09 Sep 2026 17:29:03 +0000
Renko brick high minus low
View Count: 1414
| [2020-01-03 21:28:59] |
| User357195 - Posts: 204 |
SC or anyone else that may know: I have a renko chart with wicks and have set the formula to test for a renko bricks high minus the low to be 3 ticks. However, sometimes, the renko high and low are only showing 2 ticks difference in the compact tools value window. The renko brick on the chart shows 3 ticks from high to low but the compact tools value window only shows the difference as 2 ticks. For example the CL renko bar on the chart has a low of from 62.04 to a high of 62.07. However, when I look at the compact tools value window the high is 62.06 and the low is only from 62.04. Also, when I have a formula set to test for the difference between the high and low, it shows only 2 ticks difference while the renko brick that is set to 3 ticks displays the 3 ticks. Why is the happening? I can't test for the difference correctly. One place it shows 3 ticks and the other it shows 2 ticks difference and also the charts will sometimes show the high minus the low correctly in the compact tools value window but sometimes incorrectly while the renko brick on the chart always shows the renko brick as 3 ticks. |
| [2020-01-03 21:32:29] |
| Ackin - Posts: 1865 |
Reason: badly set up ticksize or use rounding Try: Study Subgraphs Subtract/Difference Study Subgraphs Subtract/Difference + Study Subgraph In Ticks Study Subgraph In Ticks (Based on: "Study Subgraphs Subtract/Difference") Date Time Of Last Edit: 2020-01-03 21:40:57
