Date/Time: Sun, 19 May 2024 12:53:10 +0000
[User Discussion] - symbol is unknown after the second copy share the data from the first copy
View Count: 721
[2020-01-03 18:22:26] |
User199727 - Posts: 10 |
IN the second copy I try to use the same data as the first copy, but trading server is different form the first Copy, After I follow the 'Accessing Market Data from Other Instances of Sierra Chart' instruction and open dom or chart from the second copy, the chart and dom show "symbol is unknow " message, what should I do? need help thanks, following is message log. Reading Internal Order ID file. | 2020-01-03 16:48:26.928 Reading Trade Orders file. | 2020-01-03 16:48:27.057 Reading Trade Positions file. | 2020-01-03 16:48:27.058 Reading Account Balance file. | 2020-01-03 16:48:27.058 UDPListener (1412). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2020-01-03 16:48:27.086 Software version: 2028 64-bit | 2020-01-03 16:48:27.087 Usage end date: 2020-11-09 | 2020-01-03 16:48:27.087 Enabled for: Advanced Features 2. | 2020-01-03 16:48:27.087 Enabled for: Sierra Chart Historical Data Service. | 2020-01-03 16:48:27.087 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-01-03 16:48:27.087 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-01-03 16:48:27.087 Current selected Data/Trading service: Rithmic Trading | 2020-01-03 16:48:27.087 Custom symbol settings values: disabled | 2020-01-03 16:48:27.087 Chart Update Interval: 500 | 2020-01-03 16:48:27.087 Intraday Data Storage Time Unit: 1 | 2020-01-03 16:48:27.087 Time Zone: +00:00:00 (UTC+00) | 2020-01-03 16:48:27.087 2020-01-03 08:48:27 Local computer time | 2020-01-03 16:48:27.087 2020-01-03 16:48:27 Local computer time in UTC | 2020-01-03 16:48:27.087 2020-01-03 16:48:27 Local computer time in SC Time Zone | 2020-01-03 16:48:27.087 2020-01-03 16:48:26 Server time in UTC | 2020-01-03 16:48:27.087 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-01-03 16:48:27.087 Program path: C:\SierraChart5\ | 2020-01-03 16:48:27.087 Data Files path: C:\SierraChart5\Data\ | 2020-01-03 16:48:27.087 OS Version Number: 10.0 | 2020-01-03 16:48:27.088 Locale Setting: C | 2020-01-03 16:48:27.088 DLLs: UserContributedStudies_64.dll | 2020-01-03 16:48:27.088 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-01-03 16:48:27.110 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-01-03 16:48:27.137 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-01-03 16:48:27.295 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-01-03 16:48:27.295 Received 5 login tokens. | 2020-01-03 16:48:27.693 Symbol settings MD5 received. Request ID: 1. | 2020-01-03 16:48:27.906 Symbol settings are up-to-date for rithmic.trading. | 2020-01-03 16:48:27.906 Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-01-03 16:48:30.807 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:30.832 ESH0-CME 1 Min #1 | Reloading chart. | 2020-01-03 16:48:30.833 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:31.127 ESH0-CME #2 | Reloading chart. | 2020-01-03 16:48:31.128 ESH0-CME #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-01-03 16:48:31.128 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:31.328 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:31.328 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESH0-CME | 2020-01-03 16:48:31.328 Starting DelayedDownloadMonitoringTimer | 2020-01-03 16:48:31.329 Starting HDTimeoutTimer | 2020-01-03 16:48:31.329 Added historical Intraday data request for ESH0-CME to the queue. | 2020-01-03 16:48:31.329 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2020-01-03 16:48:31.329 Triggering next historical data download in queue. | 2020-01-03 16:48:31.329 HD Request # 1 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: cme | 2020-01-03 16:48:31.343 HD Request # 1 | Download start date-time: 2020-01-03 15:31:12.000 | 2020-01-03 16:48:31.343 HD Request # 1 | Using server: ds21.sierracharts.com port 10149 | 2020-01-03 16:48:31.344 Socket (1) | Creating socket. | 2020-01-03 16:48:31.345 Socket (1) | Connecting to IP: 216.1.90.129. | 2020-01-03 16:48:31.345 HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-01-03 16:48:31.456 HD Request # 1 | Sending historical data logon request message. | 2020-01-03 16:48:31.456 HD Request # 1 | Requesting Intraday data. Start date-time: 2020-01-03 15:31:12. Record interval: 1. Symbol: ESH20 | 2020-01-03 16:48:31.964 HD Request # 1 | Decompressing data. | 2020-01-03 16:48:32.016 HD Request # 1 | Receiving Intraday data for ESH0-CME starting at 2020-01-03 15:31:12 | 2020-01-03 16:48:32.148 HD Request # 1 | Timestamp of first Intraday data file record written: 2020-01-03 15:31:12 | 2020-01-03 16:48:32.149 Socket (1) | CloseSocket call. | 2020-01-03 16:48:32.149 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-01-03 16:48:32.149 HD Request # 1 | Historical data for ESH0-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-01-03 16:48:32.149 Historical data download thread signaled to stop. | 2020-01-03 16:48:32.149 HD Request # 1 | Received 3322 records from 2020-01-03 15:31:12.000 to 2020-01-03 16:38:31.000 (67.3 minutes) and wrote 3322 records for ESH0-CME | 2020-01-03 16:48:32.150 HD Request # 1 | Completion time: 1s | 2020-01-03 16:48:32.150 HD Request # 1 | Intraday data download complete for ESH0-CME. Unique request ID: 1 | 2020-01-03 16:48:32.150 Removing historical data download ID 1. | 2020-01-03 16:48:32.150 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:32.150 Rithmic Trading | Using primary service for historical data for ESH0-CME | 2020-01-03 16:48:32.150 HD Request # 1 | Download from primary service not started due to error. | 2020-01-03 16:48:32.150 Triggering next historical data download in queue. | 2020-01-03 16:48:32.150 Socket (1) | Socket gracefully closed by remote side. | 2020-01-03 16:48:32.201 Socket (1) | Closed. | 2020-01-03 16:48:32.201 Rithmic Trading | Port for executable: 59549 | 2020-01-03 16:48:33.153 Listening socket (1424). Port 59549 | Closed. | 2020-01-03 16:48:33.153 Rithmic Trading | Starting server: C:\SierraChart5\Rim\DTCBridge.exe | 2020-01-03 16:48:33.153 Created process C:\SierraChart5\Rim\DTCBridge.exe. Parameters: /Port:59549. Current folder: C:\SierraChart5\Rim | 2020-01-03 16:48:33.166 Rithmic Trading | Bridge process is running. | 2020-01-03 16:48:35.165 Rithmic Trading | Connecting to the server 127.0.0.1. Port 59549 | 2020-01-03 16:48:35.166 DTC Client socket (1) | Creating socket. | 2020-01-03 16:48:35.166 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-01-03 16:48:35.166 Rithmic Trading | Connected to server. | 2020-01-03 16:48:35.168 Rithmic Trading | Starting socket receive thread. | 2020-01-03 16:48:35.168 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-01-03 16:48:35.170 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-01-03 16:48:35.172 Rithmic Trading | Sending logon request message. | 2020-01-03 16:48:35.172 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-01-03 16:48:35.175 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart5\Rim\Rithmic.log | 2020-01-03 16:48:35.181 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-01-03 16:48:35.181 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-01-03 16:48:36.025 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2020-01-03 16:48:36.079 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2020-01-03 16:48:36.353 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2020-01-03 16:48:36.405 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2020-01-03 16:48:36.744 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2020-01-03 16:48:36.794 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2020-01-03 16:48:37.146 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2020-01-03 16:48:37.212 Rithmic Trading | Received logon response. | 2020-01-03 16:48:38.168 Rithmic Trading | Server Name: SC DTC Bridge. | 2020-01-03 16:48:38.168 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-01-03 16:48:38.168 Rithmic Trading | Successfully connected. IB='Helios', Firm='Ironbeam'. | 2020-01-03 16:48:38.168 Rithmic Trading | Trading is supported. | 2020-01-03 16:48:38.168 Rithmic Trading | Order cancel and replace is supported. | 2020-01-03 16:48:38.168 Rithmic Trading | OCO Orders supported. | 2020-01-03 16:48:38.168 Rithmic Trading | Connected to data and trading server. | 2020-01-03 16:48:38.168 Triggering next historical data download in queue. | 2020-01-03 16:48:38.168 Triggering next historical data download in queue. | 2020-01-03 16:48:38.168 Triggering next historical data download in queue. | 2020-01-03 16:48:38.168 Triggering next historical data download in queue. | 2020-01-03 16:48:38.168 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2020-01-03 16:48:38.181 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:38.307 Rithmic Trading | Starting real-time market data updates for: ESH0-CME. ID: 1 Service code: rithmic.trading | 2020-01-03 16:48:38.307 Rithmic Trading | Requesting security definition data for: ESH0-CME. ID: 1 | 2020-01-03 16:48:38.307 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:38.307 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESH0-CME | 2020-01-03 16:48:38.307 Added historical Intraday data request for ESH0-CME to the queue. | 2020-01-03 16:48:38.307 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2020-01-03 16:48:38.307 Triggering next historical data download in queue. | 2020-01-03 16:48:38.307 Delaying start of download for ESH0-CME | 2020-01-03 16:48:38.310 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 16:48:38.413 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 16:48:38.414 HD Request # 2 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: cme | 2020-01-03 16:48:39.320 HD Request # 2 | Download start date-time: 2020-01-03 16:38:31.000 | 2020-01-03 16:48:39.320 HD Request # 2 | Using server: ds23.sierracharts.com port 10150 | 2020-01-03 16:48:39.320 Socket (2) | Creating socket. | 2020-01-03 16:48:39.321 Socket (2) | Connecting to IP: 216.1.90.130. | 2020-01-03 16:48:39.321 HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-01-03 16:48:39.436 HD Request # 2 | Sending historical data logon request message. | 2020-01-03 16:48:39.436 HD Request # 2 | Requesting Intraday data. Start date-time: 2020-01-03 16:38:31. Record interval: 1. Symbol: ESH20 | 2020-01-03 16:48:39.953 HD Request # 2 | Decompressing data. | 2020-01-03 16:48:40.005 HD Request # 2 | Receiving Intraday data for ESH0-CME starting at 2020-01-03 16:38:31 | 2020-01-03 16:48:40.005 HD Request # 2 | Timestamp of first Intraday data file record written: 2020-01-03 16:38:31 | 2020-01-03 16:48:40.007 Socket (2) | CloseSocket call. | 2020-01-03 16:48:40.007 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-01-03 16:48:40.007 Historical data download thread signaled to stop. | 2020-01-03 16:48:40.007 HD Request # 2 | Received 5 records from 2020-01-03 16:38:31.000 to 2020-01-03 16:38:37.000 (6.0 seconds) and wrote 5 records for ESH0-CME | 2020-01-03 16:48:40.008 HD Request # 2 | Completion time: 1s | 2020-01-03 16:48:40.008 HD Request # 2 | Intraday data download complete for ESH0-CME. Unique request ID: 2 | 2020-01-03 16:48:40.008 Removing historical data download ID 2. | 2020-01-03 16:48:40.008 Real-time Intraday chart data file updates started for ESH0-CME | 2020-01-03 16:48:40.008 Opened cached Intraday file: C:\SierraChart5\Data\ESH0-CME.scid | 2020-01-03 16:48:40.008 Intraday chart data file opened for ESH0-CME | 2020-01-03 16:48:40.008 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 16:48:40.008 Rithmic Trading | Using primary service for historical data for ESH0-CME | 2020-01-03 16:48:40.009 Starting DelayedDownloadMonitoringTimer | 2020-01-03 16:48:40.009 Starting HDTimeoutTimer | 2020-01-03 16:48:40.009 Added historical Intraday data request for ESH0-CME to the queue. | 2020-01-03 16:48:40.009 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2020-01-03 16:48:40.009 Triggering next historical data download in queue. | 2020-01-03 16:48:40.009 Triggering next historical data download in queue. | 2020-01-03 16:48:40.009 HD Request # 3 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: rithmic.trading | 2020-01-03 16:48:40.009 HD Request # 3 | Download start date-time: 2020-01-03 16:38:37.000 | 2020-01-03 16:48:40.010 HD Request # 3 | Sending historical data request. Start date-time: 2020-01-03 16:38:37. Record interval: 1. Symbol: ESH0-CME | 2020-01-03 16:48:40.010 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2020-01-03 16:48:40.017 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-01-03 16:48:40.017 Socket (2) | Socket gracefully closed by remote side. | 2020-01-03 16:48:40.060 Socket (2) | Closed. | 2020-01-03 16:48:40.060 HD Request # 3 | Error downloading historical Intraday data for ESH0-CME. Error downloading historical Tick data. Error: permission denied | 2020-01-03 16:48:40.074 HD Request # 3 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESH0-CME | 2020-01-03 16:48:40.074 HD Request # 3 | Completion time: 0s | 2020-01-03 16:48:40.074 HD Request # 3 | Intraday data download complete for ESH0-CME. Unique request ID: 3 | 2020-01-03 16:48:40.074 Removing historical data download ID 3. | 2020-01-03 16:48:40.074 Real-time Intraday chart data file updates started for ESH0-CME | 2020-01-03 16:48:40.074 Opened cached Intraday file: C:\SierraChart5\Data\ESH0-CME.scid | 2020-01-03 16:48:40.075 Intraday chart data file opened for ESH0-CME | 2020-01-03 16:48:40.075 Triggering next historical data download in queue. | 2020-01-03 16:48:40.075 Requesting market depth updates for: ESH0-CME if supported. | 2020-01-03 16:48:43.164 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 16:48:43.271 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 16:48:43.271 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 16:48:43.271 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-01-03 16:48:43.271 Unsubscribed from market depth data for ESH0-CME | 2020-01-03 16:49:03.165 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 16:49:03.269 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 16:49:03.269 File >> Disconnect selected. | 2020-01-03 16:55:11.832 DTC Client socket (1) | CloseSocket call. | 2020-01-03 16:55:11.833 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-01-03 16:55:11.833 Rithmic Trading | Disconnected. | 2020-01-03 16:55:11.833 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-01-03 16:55:33.270 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-01-03 16:55:33.270 DTC Client socket (1) | Closed. | 2020-01-03 16:55:33.270 Rithmic Trading | Port for executable: 60120 | 2020-01-03 17:40:54.310 Listening socket (1704). Port 60120 | Closed. | 2020-01-03 17:40:54.310 Rithmic Trading | Starting server: C:\SierraChart5\Rim\DTCBridge.exe | 2020-01-03 17:40:54.311 Created process C:\SierraChart5\Rim\DTCBridge.exe. Parameters: /Port:60120. Current folder: C:\SierraChart5\Rim | 2020-01-03 17:40:54.335 Rithmic Trading | Bridge process is running. | 2020-01-03 17:40:56.321 Rithmic Trading | Connecting to the server 127.0.0.1. Port 60120 | 2020-01-03 17:40:56.321 DTC Client socket (1) | Creating socket. | 2020-01-03 17:40:56.321 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-01-03 17:40:56.321 Rithmic Trading | Connected to server. | 2020-01-03 17:40:56.322 Rithmic Trading | Starting socket receive thread. | 2020-01-03 17:40:56.322 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-01-03 17:40:56.323 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-01-03 17:40:56.324 Rithmic Trading | Sending logon request message. | 2020-01-03 17:40:56.324 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-01-03 17:40:56.325 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart5\Rim\Rithmic.log | 2020-01-03 17:40:56.328 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-01-03 17:40:56.328 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-01-03 17:40:57.089 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2020-01-03 17:40:57.154 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2020-01-03 17:40:57.408 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2020-01-03 17:40:57.456 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2020-01-03 17:40:57.789 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2020-01-03 17:40:57.853 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2020-01-03 17:40:58.184 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2020-01-03 17:40:58.247 Rithmic Trading | Received logon response. | 2020-01-03 17:40:58.324 Rithmic Trading | Server Name: SC DTC Bridge. | 2020-01-03 17:40:58.324 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-01-03 17:40:58.324 Rithmic Trading | Successfully connected. IB='Helios', Firm='Ironbeam'. | 2020-01-03 17:40:58.324 Rithmic Trading | Trading is supported. | 2020-01-03 17:40:58.324 Rithmic Trading | Order cancel and replace is supported. | 2020-01-03 17:40:58.324 Rithmic Trading | OCO Orders supported. | 2020-01-03 17:40:58.324 Rithmic Trading | Connected to data and trading server. | 2020-01-03 17:40:58.324 Triggering next historical data download in queue. | 2020-01-03 17:40:58.324 Triggering next historical data download in queue. | 2020-01-03 17:40:58.324 Triggering next historical data download in queue. | 2020-01-03 17:40:58.324 Triggering next historical data download in queue. | 2020-01-03 17:40:58.324 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2020-01-03 17:40:58.326 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:40:58.559 Rithmic Trading | Starting real-time market data updates for: ESH0-CME. ID: 1 Service code: rithmic.trading | 2020-01-03 17:40:58.559 Rithmic Trading | Requesting security definition data for: ESH0-CME. ID: 1 | 2020-01-03 17:40:58.559 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:40:58.559 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESH0-CME | 2020-01-03 17:40:58.559 Added historical Intraday data request for ESH0-CME to the queue. | 2020-01-03 17:40:58.560 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2020-01-03 17:40:58.560 Triggering next historical data download in queue. | 2020-01-03 17:40:58.560 Delaying start of download for ESH0-CME | 2020-01-03 17:40:58.569 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:40:58.684 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 17:40:58.684 HD Request # 4 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: cme | 2020-01-03 17:40:59.477 HD Request # 4 | Download start date-time: 2020-01-03 16:38:37.000 | 2020-01-03 17:40:59.479 HD Request # 4 | Using server: ds21.sierracharts.com port 10149 | 2020-01-03 17:40:59.480 Socket (2) | Creating socket. | 2020-01-03 17:40:59.481 Socket (2) | Connecting to IP: 216.1.90.129. | 2020-01-03 17:40:59.482 HD Request # 4 | Setting DTC encoding to Binary VLS | 2020-01-03 17:40:59.592 HD Request # 4 | Sending historical data logon request message. | 2020-01-03 17:40:59.592 HD Request # 4 | Requesting Intraday data. Start date-time: 2020-01-03 16:38:37. Record interval: 1. Symbol: ESH20 | 2020-01-03 17:41:00.102 HD Request # 4 | Decompressing data. | 2020-01-03 17:41:00.153 HD Request # 4 | Receiving Intraday data for ESH0-CME starting at 2020-01-03 16:38:37 | 2020-01-03 17:41:00.272 HD Request # 4 | Timestamp of first Intraday data file record written: 2020-01-03 16:38:37 | 2020-01-03 17:41:00.273 Socket (2) | CloseSocket call. | 2020-01-03 17:41:00.274 Socket (2) | Shutdown started. Waiting for graceful close. | 2020-01-03 17:41:00.274 Historical data download thread signaled to stop. | 2020-01-03 17:41:00.274 HD Request # 4 | Received 2254 records from 2020-01-03 16:38:37.000 to 2020-01-03 17:30:59.000 (52.4 minutes) and wrote 2254 records for ESH0-CME | 2020-01-03 17:41:00.275 HD Request # 4 | Completion time: 0s | 2020-01-03 17:41:00.275 HD Request # 4 | Intraday data download complete for ESH0-CME. Unique request ID: 4 | 2020-01-03 17:41:00.275 Removing historical data download ID 4. | 2020-01-03 17:41:00.275 Real-time Intraday chart data file updates started for ESH0-CME | 2020-01-03 17:41:00.275 Opened cached Intraday file: C:\SierraChart5\Data\ESH0-CME.scid | 2020-01-03 17:41:00.275 Intraday chart data file opened for ESH0-CME | 2020-01-03 17:41:00.275 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:41:00.275 Rithmic Trading | Using primary service for historical data for ESH0-CME | 2020-01-03 17:41:00.275 Added historical Intraday data request for ESH0-CME to the queue. | 2020-01-03 17:41:00.276 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2020-01-03 17:41:00.276 Triggering next historical data download in queue. | 2020-01-03 17:41:00.276 Triggering next historical data download in queue. | 2020-01-03 17:41:00.276 HD Request # 5 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: rithmic.trading | 2020-01-03 17:41:00.276 HD Request # 5 | Download start date-time: 2020-01-03 17:30:59.000 | 2020-01-03 17:41:00.276 HD Request # 5 | Sending historical data request. Start date-time: 2020-01-03 17:30:59. Record interval: 1. Symbol: ESH0-CME | 2020-01-03 17:41:00.276 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2020-01-03 17:41:00.287 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-01-03 17:41:00.287 Socket (2) | Socket gracefully closed by remote side. | 2020-01-03 17:41:00.327 Socket (2) | Closed. | 2020-01-03 17:41:00.327 HD Request # 5 | Error downloading historical Intraday data for ESH0-CME. Error downloading historical Tick data. Error: permission denied | 2020-01-03 17:41:00.340 HD Request # 5 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESH0-CME | 2020-01-03 17:41:00.340 HD Request # 5 | Completion time: 0s | 2020-01-03 17:41:00.341 HD Request # 5 | Intraday data download complete for ESH0-CME. Unique request ID: 5 | 2020-01-03 17:41:00.341 Removing historical data download ID 5. | 2020-01-03 17:41:00.341 Real-time Intraday chart data file updates started for ESH0-CME | 2020-01-03 17:41:00.341 Opened cached Intraday file: C:\SierraChart5\Data\ESH0-CME.scid | 2020-01-03 17:41:00.341 Intraday chart data file opened for ESH0-CME | 2020-01-03 17:41:00.341 Triggering next historical data download in queue. | 2020-01-03 17:41:00.341 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:48:02.113 ESH0-CME #2 | Reloading chart. | 2020-01-03 17:48:02.114 ESH0-CME #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-01-03 17:48:02.114 Requesting market depth updates for: ESH0-CME if supported. | 2020-01-03 17:48:03.320 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:48:03.445 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:48:03.445 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 17:48:03.446 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-01-03 17:48:03.446 Unsubscribed from market depth data for ESH0-CME | 2020-01-03 17:48:18.320 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:48:18.439 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 17:48:18.439 ESH0-CME Daily #2 | Reloading chart. | 2020-01-03 17:54:16.453 ESH0-CME Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart5\Data\ESH0-CME.dly | 2020-01-03 17:54:16.463 Starting DelayedDownloadMonitoringTimer | 2020-01-03 17:54:16.959 Starting HDTimeoutTimer | 2020-01-03 17:54:16.959 Added historical Daily data request for ESH0-CME to the queue. | 2020-01-03 17:54:16.966 Triggering next historical data download in queue. | 2020-01-03 17:54:16.966 HD Request # 6 | Downloading Historical Daily chart data for ESH0-CME. Starting date: 1970-01-03. Service: rithmic.trading | 2020-01-03 17:54:16.971 HD Request # 6 | Requesting historical Daily data for ESH20 starting at 1970-01-02 | 2020-01-03 17:54:16.971 HD Request # 6 | Receiving historical Daily data for ESH0-CME starting at 2018-12-20 | 2020-01-03 17:54:18.461 HD Request # 6 | Writing historical Daily data to the file ESH0-CME.dly | 2020-01-03 17:54:18.461 HD Request # 6 | Received 261 records from 2018-12-20 00:00:00 to 2020-01-03 00:00:00 (380.0 days) and wrote 261 records for ESH0-CME | 2020-01-03 17:54:18.472 HD Request # 6 | Completion time: 2s | 2020-01-03 17:54:18.472 HD Request # 6 | Daily data download complete for ESH0-CME. Unique request ID: 6 | 2020-01-03 17:54:18.472 Removing historical data download ID 6. | 2020-01-03 17:54:18.472 Triggering next historical data download in queue. | 2020-01-03 17:54:18.472 ESH0-CME Daily #2 | Reloading chart. | 2020-01-03 17:54:18.954 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:54:26.832 ESH0-CME 1 Min #3 | Reloading chart. | 2020-01-03 17:54:26.833 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 17:54:41.844 ESH0-CME #4 | Reloading chart. | 2020-01-03 17:54:41.845 ESH0-CME #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-01-03 17:54:41.845 Requesting market depth updates for: ESH0-CME if supported. | 2020-01-03 17:54:43.334 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:54:43.461 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-01-03 17:54:43.462 Unsubscribed from market depth data for ESH0-CME | 2020-01-03 17:54:48.330 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 17:54:48.399 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 17:54:48.399 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 18:03:43.257 ESH0-CME #1 | Reloading chart. | 2020-01-03 18:03:43.257 ESH0-CME #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-01-03 18:03:43.258 Requesting market depth updates for: ESH0-CME if supported. | 2020-01-03 18:03:43.328 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 18:03:43.396 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-01-03 18:03:43.397 Unsubscribed from market depth data for ESH0-CME | 2020-01-03 18:03:48.320 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 18:03:48.387 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 18:03:48.387 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 18:03:50.739 ESH0-CME 1 Min #1 | Reloading chart. | 2020-01-03 18:03:50.741 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 18:04:36.494 ESH0-CME 1 Min #1 | Reloading chart. | 2020-01-03 18:04:36.496 Using SC exchange feed2. Symbol: ES?#-CME | 2020-01-03 18:04:40.703 ESH0-CME #2 | Reloading chart. | 2020-01-03 18:04:40.703 ESH0-CME #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-01-03 18:04:40.704 Requesting market depth updates for: ESH0-CME if supported. | 2020-01-03 18:04:43.322 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 18:04:43.395 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-01-03 18:04:43.395 Unsubscribed from market depth data for ESH0-CME | 2020-01-03 18:04:53.322 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2020-01-03 18:04:53.388 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2020-01-03 18:04:53.388 |
