Date/Time: Sun, 19 May 2024 17:10:44 +0000
VbP side by side
View Count: 677
[2020-01-03 17:43:54] |
User75949 - Posts: 108 |
Is there any chance to set the VbP drawing changing from right to left into left to right drawing? not position. As you can see from the attached image I would like to have the Volume Profile exactely as it is and the other profile (that with blue /red a delta profile) still on the right side but from left to right hopefully to be put attached to the other VbP profile as on the other example attached. regards |
ESH0 2t.jpg / V - Attached On 2020-01-03 17:42:05 UTC - Size: 199.1 KB - 308 views Side by Side Profile.jpg / V - Attached On 2020-01-03 17:42:58 UTC - Size: 17.8 KB - 267 views |
