Date/Time: Sat, 29 Mar 2025 14:34:06 +0000
Three Line break Support/Resistance Lines
View Count: 2522
[2020-01-03 16:32:17]
User434251 - Posts: 15
Is there a way to get sierra to draw lines when a new line is created? (see attached)
I would also like to be able to have the line extend until it is breached.
Please let me know if this is possible.
Thanks in advance.
imagecocoa-3l.png / V - Attached On 2020-01-03 16:31:35 UTC - Size: 202.52 KB - 909 views
[2020-01-03 19:19:57]
It is possible to do this, but it would need to be programmed using ACSIL. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
[2020-01-03 19:49:55]
Ackin - Posts: 1865
User434251)
Hi, Looks like as simple study, if you want it will be in tomorrow's update.
Free study: Three line break SR lines
contact link:
[2020-01-04 00:29:18]
AWESOME! Many thanks!!!
