Date/Time: Sun, 19 May 2024 14:15:11 +0000
spreadsheetstudy
View Count: 537
[2020-01-03 15:47:36] |
User895425 - Posts: 7 |
hi when i try to export the studyspreadsheet to excel i get an error message and i can't export it i attach the error message as a jpg pic thanks |
excel-error.jpg / V - Attached On 2020-01-03 15:47:05 UTC - Size: 413.2 KB - 236 views |
[2020-01-03 19:00:40] |
Sierra Chart has removed support for Microsoft Excel. This is no longer supported. Update to the current version.
