Date/Time: Sun, 19 May 2024 17:10:42 +0000
Error setting System Date-Time
View Count: 1054
[2020-01-03 13:28:55] |
User734688 - Posts: 23 |
I've just changed to a new account and am getting this error message Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2020-01-03 08:17:08.817 * Can't find anything about it on the Help Pages. How can I fix it? Elena |
[2020-01-03 13:57:13] |
This error is an indication that the operating system permissions is not allowing a program to set the system Date-Time. This is documented here: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
