Date/Time: Sun, 19 May 2024 19:22:47 +0000
evening sessions default start time question
View Count: 493
[2020-01-03 02:03:04] |
user10000 - Posts: 41 |
Hi i noticed the evening session start time default is set to 16:15:00 on ES when i update from server compared to other charting platforms which start at 16:30:00 giving mixed candles because of this. just wanted know why that was the case before i make any changes to the evening start time
Date Time Of Last Edit: 2020-01-03 03:02:44
estime.png / V - Attached On 2020-01-03 02:07:06 UTC - Size: 122.16 KB - 230 views |
[2020-01-03 04:17:52] |
You can change it.
