Date/Time: Sun, 19 May 2024 20:36:20 +0000
[Programming Help] - Problem with custom studies (SAI.dll)
View Count: 669
[2020-01-02 19:34:04] |
User146056 - Posts: 1 |
I started with Sierra chart approximately a month ago primarily to use a set of custom studies created by Gary Steckel (The SAI custom studies). For a period of roughly weeks or more, I successfully used such studies after being enabled by Gary. Starting this weekend, I have become unable to successfully load these same studies when I launch Sierra. Gary assures me I am still enabled by him to use the studies. Please advise on best way to fix this issue. Thanks in advance, Ravi |
[2020-01-02 21:17:10] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log After that provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
