Date/Time: Sun, 19 May 2024 21:13:30 +0000
Live Data not working
View Count: 568
[2020-01-02 18:23:12] |
Markus Lienhart - Posts: 8 |
Dear all, My account name is klinge369. I have a problem with live data for EUREX. My FDAX March ´20 live feed is only working with a delay of around 1 hour. Do you know what the problem could be? Since I´m in Austria working from my Notebook the live feeds are not working. Kind regards Markus |
[2020-01-02 22:07:13] |
This question is in regards to futures data. So therefore, refer to: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
