Date/Time: Sun, 19 May 2024 20:16:44 +0000
Moving Average indicator Tag
View Count: 538
[2020-01-02 17:22:06] |
Bubba - Posts: 30 |
Hello I'm wondering how to put a tag that shows on the right side of the chart that tells which MA is which. Thanks |
[2020-01-02 17:39:44] |
Ackin - Posts: 1865 |
MA name.png / V - Attached On 2020-01-02 17:39:04 UTC - Size: 144.71 KB - 222 views |
[2020-01-02 17:55:33] |
John - SC Support - Posts: 31733 |
As Ackin stated, use the Value Name option. Refer to the documentation here: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
