Date/Time: Sun, 19 May 2024 21:02:03 +0000
Missing Spread Data
View Count: 430
[2020-01-02 16:54:03] |
User911267 - Posts: 25 |
We have noticed that spread data for RB-HO appears to be missing/incorrect in your historical files. We can get history for as far back as RBQ19-HOQ19.RB.FUT_SPREAD.NYMEX. However, anything prior to this only comes across with a few records (Like 50-200 records). Is there a limit to the amount of historical data for spreads you keep?
[2020-01-02 18:40:26] |
Sierra_Chart Engineering - Posts: 14423 |
There may very well be an issue with RB spreads. We will work on this over the next few days. For other markets, there will be spread data for multiple years.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-02 18:41:07
