Date/Time: Sun, 19 May 2024 17:52:09 +0000
How to confirm server side OCO with new SC TT FIX routing
View Count: 632
[2020-01-02 16:29:48] |
User205938 - Posts: 8 |
I just setup my account according to the instructions laid out here: Sierra Chart / Trading Technologies Futures Order Routing Service In previous posts regarding OCO it says that to verify if my orders are indeed server side it will say it in the Trade Activity Log under Action Source. But with the new configuration it doesn't say Server Side OCO or Client Side OCO. What should the message be? NOTE: I do have both Server Side OCO and Bracket Order boxes checked in the General Trade Settings. |
[2020-01-02 19:04:01] |
This is an example of what you will see: ActivityType DateTime Symbol OrderActionSource InternalOrderID BuySell ServiceOrderID OrderType OrderStatus Quantity FilledQuantity FillPrice Price Price2 TradeAccount OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID HighDuringPosition LowDuringPosition Note AccountBalance Order 2020-01-02 14:03:16.985 ESH20_FUT_CME ESH20_FUT_CME[M] Daily #1 | User order entry | Last: 3242.5 | Server side bracket order 9290 Buy Market Order Sent 1 SC1001 Open Order 2020-01-02 14:03:17.019 ESH20_FUT_CME ESH20_FUT_CME[M] Daily #1 | User order entry | Last: 3242.5. Attached Order | Server side bracket order 9291 Sell Limit Order Sent 3245.00 SC1001 Close 9290 Order 2020-01-02 14:03:17.051 ESH20_FUT_CME ESH20_FUT_CME[M] Daily #1 | User order entry | Last: 3242.5. Attached Order | Server side bracket order 9292 Sell Stop Order Sent 3240.00 SC1001 Close 9290 The text you want to look for in this case is: server side bracket order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-02 19:04:50
[2020-01-02 20:20:46] |
I reviewed my TradeActivity Log and it still shows that it is set to Client Side OCO. I attached a copy for reference. Are there limitations to the types of OCO orders we place? By that I mean, does it matter if I have 2 targets and 1 Bid/Ask QTY stop with a trail to BE? Or does it require a 1 to 1 ratio? |
[2020-01-03 04:49:05] |
Yes actually that does reveal the issue. Since one of those is a managed type (Bid/ask quantity stop), there cannot be a server-side bracket order.
