Date/Time: Sun, 19 May 2024 20:16:47 +0000
Low bandwidth option
View Count: 500
[2020-01-02 15:08:34] |
moya - Posts: 19 |
Hello, I have a question regarding the SC Server settings "Low bandwidth option". Below what bandwidth the enabling of this option should be considered? Thanks and Good year |
[2020-01-02 16:23:31] |
We cannot answer that question. This is never going to be the proper approach to the decision to use that option. There is not a clear correlation like this. The decision to use that option is simply if the data is lagging by more than a few seconds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
