Date/Time: Tue, 04 Feb 2025 03:00:19 +0000
CME paied not activated
View Count: 547
[2020-01-02 08:50:31] |
User657945 - Posts: 226 |
Hi please check why I paid the CME real time and it is not working, while all the others services activcated this morning are running well. thx
[2020-01-02 12:46:51] |
This is resolved for your account and we recommend that you open an account with just a small balance like 500 USD with the broker AMP on the TT order routing: Sierra Chart / Trading Technologies Futures Order Routing Service This will avoid the problem altogether. Otherwise, this will be is an issue going forward. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
